Help me build my 103
Old 11-05-2013, 04:38 PM
018245's Avatar
018245
018245 is offline
Have a great deal on the above...but obviously I want to do it right the first time.
Old 11-06-2013, 04:57 AM
6 gun's Avatar
6 gun
6 gun is offline
Received 1,747 Likes on 982 Posts
SE 103+ heads are great, if you have a set of
SE 103+ pistons to go with them and a set of
SE 259E cams. only problem is they quit making
the 103+ heads and pistons a long while ago.
Here you go have a little fun with this, but If
I had it to do it all over again I would go with a 107
http://www.harley-davidson.com/en_US..._SE13_Full.pdf
Old 11-06-2013, 02:06 PM
djl's Avatar
djl
djl is offline
Received 2,232 Likes on 1,614 Posts
Nothing special about the 103" cylinders. The pistons are configured to be compatible with the heads but you don't have the heads. I would pass on the "deal" and work with what you have. Bore to 3.932" to fit aftermarket piston kit and have the heads decked, ported, etc. to work with cams of your choice.
Old 11-07-2013, 04:51 AM
Gooey2's Avatar
Gooey2
Gooey2 is offline
Go look at fuel moto's builds , they have quite a few Dyno's and combinations. Will get you going in the right direction. Well my two cents
Old 11-07-2013, 08:36 AM
Danofxdx's Avatar
Danofxdx
Danofxdx is offline
I love the easy start cams 583, but they do make a funny sound when I shut it off sometimes, but I like the fact that I don't have to worry about compression releases. had my engine built for longevity not HP or TQ, more than happy with the performance with the exception of the S&S G carb, runs fine but think that a built 44 CV would perform better!
Old 11-14-2013, 02:27 PM
FXDFan's Avatar
FXDFan
FXDFan is offline
Last winter I had a "103" war going with my cousin lol.
I ended up with pistons/jugs from Scott @ hillside, along with TW8-6 cams.
Heads were already level B FM. Ended up at 113/118. Bent the tach like crazy.
Started pulling about 2700, then was REALLY coming on at 3,000
This was in my SG, if you had it in a Dyna be even quicker...
okiesteve
02-11-2014 06:10 PM
nutter
05-03-2012 04:30 PM
harleymark
Dyna Parts
08-29-2010 08:12 PM
Rebel78
124
01-03-2009 10:27 AM
GasCan
09-18-2008 10:07 AM
Quick Reply: Help me build my 103
