CAM KIT QUESTION
RE: CAM KIT QUESTION
The chain assembly, even the newer one in the 07s, requires more HP to turn the chains, tensioner & cams than does the gears set-up. On a mild street motor, I wouldnt think it would be worth the extra $$ just to go with gears.
Reno
www.FastAire.com
Reno
www.FastAire.com
go to nightrider.com and look at the cam specifications charts. there is a difference in those cams in the intake openings and closings, exhaust openings and closings, durations, etc. - all of which affect the torque and horsepower at different rpm's. you need a good mechanic to give you advice on what cam to use based upon what you want in your riding (early torque or later rpm horsepower, riding two up or solo, street riding or touring long miles, etc), the engine build, exhaust systems, etc.
much more involved than just whether chain driven or gear drive.
