Woods cams? Help??
Woods cams? Help??
I'm looking to tap into the vast pool of experience getting around out there.
I have a 2014 CVO Breakout on order - wont get it here for a few months yet. I want to plan the motor work already though. Can anyone advise if they have substituted Woods cams for the screamin eagle ones when putting a stage 3 or 4 kit through the 110" HD motor? I've heard nothing but good reports on the woods cams thus far. I will be running a V&H two into one system as well. Is there anything else I need?
Any advice appreciated.
woods cams make HP,but need a lot of compression are can be on the noisy side,we wont use them here unless the customer just HAS to have them,ide look at the S&S .570 set at 10.0-1,the .585 set at 10.5-1 or the .625 set at 10.8-1 to 11.0-1. with having the heads worked with what ever cam you choose
The reason I'm interested in woods cams is because my mate brought his 08 fatboy back to Australia when he returned from a 2 1/2 year working stint, and he had basically nothing but V&H pipes, Woods (888's I think) cams and a power commander done to the motor. Now that his bike is back here in Australia, it keeps up with another mates 2013 Fatty with a stage 4 kit through it. And it runs better.
Doesn't the stage 4 kit already come with better high compression heads? And I'm really not concerned with noise - except to the detriment of the engine of course. Lets say I was one of your customers who just HAD to have Woods cams - which would be the most appropriate for a stage 4 110 + V&H pipes?
Fenrirsmayhem
01-27-2019 03:18 PM
