Overlap
Overlap
I see where HD is increasing the overlap among other specs on the 2014's. Is the overlap what causes the noises the seem to come though the air cleaner when performance cams are added? On a further note; has anyone actually decreased their valve train noise after adding another quarter turn to the pushrod adjustment ? All of my noise is after mid range RPM's with a fairly quiet idle.
the 2014 motors will be 10.1-1 compression,the increase in overlap will allow for a better cylinder fill for better high RPM power (and just more power in general), the higher static compression will keep the corrected compression up,letting it not fall on its face in the low & midrange RPM`s (lots more power there too)
Thanks guys, what causes the " grumble " coming from the AC area when the performance cams are installed? Lift , duration or what. I am asking because it seems that most engines with performance cams have the noise whereas they did not stock. In order to lesson the noise what feature do you keep closer to stock?
Thanks
Thanks
Thanks
Thanks
