Sponsored by: Jekill and Hyde
Where will this build put me??
Old 07-22-2013, 12:32 PM
djl's Avatar
djl
djl is offline
Received 2,223 Likes on 1,608 Posts
No wonder it was pinging on the way home; domed pistons, 80cc heads and intake close at 38*; no surprise there. Good that you were able to tune the ping out but if all the numbers you have provided are correct, static CR should be around 11:1 and CCP close to 220psi (sea level). I have never run that much compression in a street motor and wouldn't recommend it. I stick pretty much in the 10.5:1, corrected 9.3-9.5 and CCP 185-190psi; I guess I am just a "scaredy cat" when it comes to more compression!
Glas you finally found/fixed the problem; I know how frustrating that situation can be. Good luck! I would like to see the dyno numbers when you get her tuned.
Plated & Screwed
Engine Mechanical Topics
05-25-2016 10:40 AM
aposto
04-18-2014 06:42 AM
02 softail
01-09-2014 02:59 PM
timberland
02-26-2012 04:40 AM
bagr
02-06-2008 07:36 PM
Quick Reply: Where will this build put me??
