95 vs. 103 with wild pigs (update after the build)
Ok, I went with the 103 HD kit at the dealer. Thanks to the many who gave their opinion on my original post. The dealer called today and I went out to take a look at the bike. I was very happy and the dyno sheet was close to my 100/100 goal. It dyno'd at 96.38hp and 101.45tq. I was surprised how much louder the bike was with the same 1.75 baffles in the Wild Pigs and can't wait until the new 2.5's arrive on Friday. I will put those in and the dealer says they will dyno it again. They also told me to put some miles on it this spring and bring it back once I have broken it in asthey think there is a little untapped power left in the buildbut they want to wait to push it until I get some miles. The biggest problem is that I can't ride this thing for a couple months due to the weather in the great state of South Dakota. So, although I am sure there are better builds and I haven't actually ridden the bike yet, I think I will be satisfied. My dealer is good to deal with and they came in almost exactly on the numbers they told me the bike would do with my set up. As a refresher, I did the HD 103 Stroker kit with the cams, pistons, cylinders, heads, flywheel. I already had the SERT, V&H headers (2/2), screaming eagle air cleaner andWild Pig slip on pipes. I hope this helps someone considering the same thing. I will give an update in the spring after some miles and the final tune. Thanks!
RE: 95 vs. 103 with wild pigs (update after the build)
Westy-
Good luck with the new build... your fun factor is about to go way up!! Which cams did you use in your build? I have the 255's in my 103, lots of low end tq, but they flatten out too soon. Also, did you keep your heads stock? If so, those are good numbers for stock heads. Any chance you can post a copy of your dyno run?
I have the 255 cam. The new Screaming Eagle heads were included in the Screaming Eagle package I purchased. I will try to figure out how to post they dyno sheet. I scanned it but I can't figure out how to insert it into this forum. I will keep trying.
