Check Engine Light
Old 06-29-2013 | 05:30 PM
Newharleylover's Avatar
Newharleylover
Default Check Engine Light
I changed the fluids in all 3 holes a couple of days ago. While I was at it I adjusted the clutch. I took her for a ride right after that and my check engine light came on about 2 minutes into the ride. She was running no different from normal and there was no power loss at all. On some starts the light comes on for 4-5 seconds before it goes out and on other starts it doesn't go out at all. So I checked for codes and it gave me po577 cruise control input high. So just out of curiosity I took her for a rip and tried the cruise control and it worked for a couple minutes and disengaged the cruise. I tried it 2 or 3 more times and got the same result. It seems kind of odd to me that none of this has happened before I changed all the fluids and if it's an electrical problem why would it have anything to do with the check engine light?
Old 06-29-2013 | 05:45 PM
QC's Avatar
QC
My WAG is you have a short in your cruise circuit somewhere leading something to get hot and trip a breaker. My next WAG is the check engine light comes on to let you know something is wrong somewhere. I don't know of a different warning light that might be on a touring bike though.
Old 06-29-2013 | 06:33 PM
Newharleylover
I forgot to mention that the last time my cruise control wouldn't work was when I found out my rear brake light switch was fried to a crisp. I had it switched out for a new one but the check engine light never came on at the time.
Old 06-30-2013 | 09:19 AM
Newharleylover
Guess I have to take it to my indy to have him check it out. Maybe it's the ccm or the ecm or a relay or some ****. I don't have Benjamins dripping out my *** so I thought I would ask here first.
Old 07-01-2013 | 06:41 AM
Assegai's Avatar
Assegai
I'd check the variable speed sensor.
ChromeJunkie
06-23-2017 07:50 AM
tjcaron
09-08-2013 07:54 AM
SouthpawHD
07-12-2013 08:03 AM
SoFla
"The Florida Crew"
58
12-19-2009 10:18 PM
SILVERTEX
07-22-2008 06:43 PM
Quick Reply: Check Engine Light
