Engine Oil Leak
Engine Oil Leak
Gents, my '04 XL1200C has an oil leak on the aft side of the engine. Although I do work on my bikes, I haven't messed with the engine yet so I don't know exactly how to describe the location, so I included a photo. Also, is there any easy fix for this or am I pretty much effed? Thanks!
Can't really see the link but it looks like a seeping head gasket. Try re-torqueing the head bolts; if that doesn't stop the leak you will likely need to replace the head gasket.
Before you re-torque head bolts, look real close and make sure the leak is not coming from the rocker box cover gasket.
I agree look real close at the back of the lower rocker box gasket and make sure it is not leaking there and running down.
