Cams
Old 06-03-2013, 08:28 PM
bigdog1949's Avatar
bigdog1949
bigdog1949 is offline
Default Cams
Have an 02 flhtc 88 ,pc3 ,screamin eagle exh and a/c,what cam would work with this,and would it be worth it ??,nothing radical !!
Anybody????????????
Old 06-03-2013, 08:38 PM
hdslam's Avatar
hdslam
hdslam is offline
Andrews 21N, if you are doing a cam set conversion with new roller chains and a 2007 and up cam plate. This upgrade will get you the new hydraulic chain tensioners to get away from the spring loaded tensioners. If no cam plate conversion, the 21's of the standard version will do. Check the Andrews website for the exact camshaft number for a direct replacement without the plate upgrade.
The 21N is close to stock, but pulls like a freight train on the bottom end. They work great with the 88" and the minimal upgrades you have already done.
Old 06-03-2013, 08:47 PM
bigdog1949's Avatar
bigdog1949
i want to keep the stock setup,i already installed the cyco tensioners,and cam bearings,would that cam work ??
Old 06-04-2013, 06:10 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Anybody????????????
We would suggest an Andrews 26.
Scott
Old 06-04-2013, 06:38 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
the CRANE 300-2 is a nice,touring cam set
Old 06-04-2013, 10:09 AM
djl's Avatar
djl
djl is offline
Received 2,232 Likes on 1,614 Posts
Aren't you glad you asked; already have three to choose from. I would throw the S&S 551 into the mix as well. Stick around and you will get some more suggestions.
EDIT: The Redshift 525 I another option; getting a headache yet??
Old 06-04-2013, 12:26 PM
Pumba11's Avatar
Pumba11
Pumba11 is offline
I am an extremely happy Andrews 21 cam owner. Fantastic power for everyday touring bike riding. It is a torque monster. Love it.
Old 06-04-2013, 12:46 PM
Skip's Avatar
Skip
Skip is offline
As djl said! I have the S&S 551 in a 2005 flht, 88 ci, very pleased
Old 06-04-2013, 04:37 PM
prodrag1320
the .551 is a very nice cam set,we just set it at a little higher compression than stock.if he`s planning on playing with the heads/compression,the .551`s would be a great choice.ill throw the S&S .583`s in the mix too
Old 06-04-2013, 04:58 PM
woodsietx's Avatar
woodsietx
woodsietx is offline
I've had a set of S&S 583s for little over a month. Running a 2008 96 with V&H Big Shots controlled by a Power Commander. My mechanic found a close map from the Dynojet web site and it's made a huge difference in both the throttle kick and in the fuel consumption. (Both went up considerably). Says that if I should desire to do any other tweaks to the motor, the cams should work going forward.
This was the first set he installed and is pleased with the results. He has used other S&S cams with excellent results as well.
Quick Reply: Cams
