thanks,i looked up andrews and they recommend there gears,is it nessary??
but thanks for all the responces,great website !!!
You don't need geardrives, but as long as your pinion shaft TIR, is at .003" or less, and you have the extra dough, then yes, they are a great upgrade.
One of the reasons I suggested, the 26 cam, is that, IF, you wanted more later, the cam surrounded by say a 98" big-bore kit, with the compression optimised, and some mild head work, is quite a snappy combination.
Scott
Scott i have a set of heads and cyls off my 07 flhtc,can i use them on the 02,what mods would they need,what benifit would it be??,heads need to be done pol and port,could u pm me on a price,Bill
Those '07 heads would be an improvement without any work; they flow better than the OEM '02 heads. Combine the heads with a .030" head gasket or not, depending on cam selection, and you will see a nice gain. I used a set of those heads, cleaned up, milled for some compression and a SERDI valve job on a 95" build for a buddy's Deuce. Motor made 104TQ/93HP. No port/polish; compression is your friend.
Of course headwork will make a difference; just depends on how much money you wan to spend.
