stuck exhaust gaskets
04-27-2013, 12:57 PM
I'm in the process of installing a new exhaust system and after removing the stock exhaust, I've found the old exhaust gaskets stuck inside opening.
Has anyone run into this, and what's the easiest way to remove them without doing damage to the engine?
Mike
04-27-2013, 01:01 PM
You could use a pick tool, I used a small screwdriver. Think dig
04-27-2013, 01:13 PM
I do it the same way as Ynots; reach in with a bent dental pick and pull. Sometimes you need to work around the gasket
04-28-2013, 08:25 AM
I use a right angle pick tool that came with a screwdriver set from Lowes.
You just force it behind the gaskit and pull.
Billy
04-28-2013, 08:27 AM
^^Yep...set of pick tools works wonders for removing things^^^
They look like this:
paid4c4
Exhaust System Topics
15
04-19-2015 06:50 AM
Landcruiser
08-18-2014 11:56 PM
iDodgimus
02-06-2012 10:39 PM
frankiefire702
02-27-2011 09:36 PM
ltkris
06-15-2006 01:57 AM
