Leaking Rocker Cover
Well I was really pissed until I searched the forum and found many a leaking rocker box cover. I only have 3500 miles on a 2005 Springer, the rear rocker box cover is seeping oil, im going to check the bolts and make sure there snug, then what?? I guess remove covers and replace gasket?? any suggestions are appreciated, im a rookie wrench, but ill give it a shot. Im not paying some clown $500 to put a new gasket in................
RE: Leaking Rocker Cover
ORIGINAL: Unibomber
Easy job, but right from the start get in the habit of taking your time & doing things right w/your bike. Use the TQ sequence in your service manual & use a TQ wrench to snug it back to spec. Snap-On makes a torque adaptor that'll help here:
http://buy1.snapon.com/catalog/item....mp;dir=catalog
Overtightening and/or usingthe wrong sequence can warp your rocker cover & it'll weep from now on if you warp it. If it still leaks afteryou tq it back downthen it'stime for a new gasket; follow SM instructions.
Nobody loves your bike as much as you do.
VicW.
VicW.
