Bike hesitates on acceleration
I have a 1994 Softail that has been sitting, off and on, most of the last two years. It gets a ride once in a while. Now, it has a slight hesitation on acceleration or when I'm crusing at low RPM it hick-ups. It runs strong under full acceleration, it's just at low RPM and on acceleration. Any idea of what the problem might be? By the way, I've replaced the intake seals and carb seal but it didn't solve my problem. Thanks
RE: Bike hesitates on acceleration
I would say the carbs varnished. Get a rebuild kit, take everthing apart (count the number of turns from seat on all the adjustment screws and write it down), a gallon of the carb cleaner with the basket in it, soak it over night (not the rubber part thou) then blow out all the orifaces wipe it all downand reassemble, seat adjustment screws and back out the number of turns for each and it should fire up fine. Do final adjustments after you get it to operating temp.
