Is this battery problem?
Or something else. 2010 SG stage one pipes and A/C, Rev Per EMS tuner, use a battery tender most of the time when I'm not riding.
Here's the issue. When I cold start the bike the starter motor seems to stall like the engine suddenly has a lot of compression or the batteries low. It won't turn the engine over. I let off and give it a second. It's starts on the second try but not without a nice backfire out the pipes. Once the bike warms up it starts normally. It only dose this on the fisrt start of the day. My neighbors would really appreaciate a solution to this.
Symptomatic of a weak battery; pull it out and load test. The battery tender should be on all the time to maintain a fully chaged battery. When the battery gets pulled down a time or two, the tender won't bring it back. Batteries should last about four years if kept on a tender when not running; some will last longer.
