Need help with evo cam install
When lining up the timing mark on my cam gear with timing mark on pinion gear ,at what position should the front piston be in? Can the cam be installed 180 deg off ?[/align]Is there any correlation between the TDC mark on the flywheel and the timing mark on the pinion shaft ?[/align]Thanks in advance.[/align]
RE: Need help with evo cam install
If you haven't seen this, read it.
http://www.nightrider.com/biketech/hdcaminstall00.htm
If it's too late and you didn't align the timing marks or turned the crank without the cam in place, you've got a 50/50 shot!
Actually it shouldn't be too tough to figure out if you stop to think about valve function at a given piston position.
When looking at the cam side of the engine, the crank rotates clockwise. When the front piston is at TDC of the compression stroke, valves will be closed (lifters off the cam lobes). Shortly thereafter, within a half rotaton of the crank, the exhaust valve should begin to open.
Disclaimer: I've never done a cam swap but I'm about to. Someone PLEASE speak up if I've written anything wrong!!
PS...there's a lot of good reads on this site.
ORIGINAL: vinnyflstc
doin the same here but when i line up the marks as service manual says, my front piston is down low , nearly at its lowest ,is this ok?
