Kent moore en-46745 piston pin clip replacer tool
I bought one of these circlip tools off ebay trying to save a few $. It is almost like the HD tool but has a different diameter tip. The Wiseco pistons I'll be using have wrist pin ID of 0.620 and the OD of the largest tip that came with the tool is 0.570 or so. Has anyone successfully used this GM tool with the largest tip even though it's smaller than the HD wrist pin ID? I can't seem to get the tool to grab the clip and wonder if I need a larger tip. I've read and watched the videos on removing w/screwdriver and putting them in by hand or using a 3/4" copper union and 5/8 socket, but I'm trying to make the tool made for the job work. Thanks.
We have 2 cabinets full of specialty tools we've not only purchased, but manufactured as well.
We pop those right in with a small screwdriver as well.
Have not used anything easier/quicker yet.
Scott
Have you used Kuryakyn (CP?) piston with the thicker diameter retaining circlip. I admit that I couldn't get them in without the tool. The smaller wire diameter are no problem. Could use some hints on installing the clips with the larger diameter wire.
Scott
Shawrco
The guide tip on mine is .543". If the tip is not removable: You can drive out the spring pin and remove the plastic handle and chuck it in a lathe and turn it down. The tool I have is not supposed to fit forged pistons. I had to elongate the relief that the hook fits into on the piston with my dremel. Worked like a charm. Could you post me a link to the tool.
Shawrco
http://www.spxtools-shop.com/Harley/PDF/HD-42317-A.pdf
I couldn't tell for sure from the photo but suspected the pilot tip on the HD tool was not removeable. A member on Harley Tech Talk forum posted that the pilot on his HD tool is 0.560. The Kent-Moore GM version comes w/two different diameter pilots and there is a third available for the LNF 2.0L ECOTEC engines, but I don't know if it's larger or smaller than the pilots I have. My largest pilot is about .543 also, so you must have the GM tool as well. I didn't know the tool wasn't necessarily meant for forged pistons, but what you describe is the trouble I've had trying to use the tool so far (besides the pilot is much smaller than the ID of the wrist pin) - the hook jaw won't engage the clip from inside the relief in the piston. Take a look at the instructions link.
This is the tool that I bought.
http://www.amazon.com/Slinger-Airflo.../dp/B000GUWOWG
Use a dremel with a carbid burr and elongate the dimple relief.
