opinions on building a good TC88, input please
looking for imput on the folks with more experience in hopping up the 88"...
I dont want a massive hot rod here, just want to liven the 88 up a little bit. What im looking into is cams and heads, dont really have a desire to do a big bore, was told there is more bang for the buck in cams and heads. i have a plan in mind which i will list but any input would be great, thanks guys
what im looking at doing:
-fueling cams ( going to get in touch with them for what they recommend)
-updated cam plate and oil pump along with replacing cam bearings
-and researching into head porting, big boys heads seems reasonable, any other recommendations appreciated as well
was also wondering about shaving the heads to bump up the compression some?
All offer basic packages with some wrinkles that might be a better option than BigBoyz.
Off the top of my head, a set of velocity ported heads, Andrews 26 cams, a good pipe and tune will be a huge improvement but there are many ways to skin the cat.
I did this before I went to a big bore. I used Don Dorfman (http://deweysheads.com/) I went with TW37H cams, 2-1 pipe, PCV,30tooth sprocket and Don's head work. My bike ran really well and was fun as hell. Once I had the $$ to go big bore I took my heads back to him for a little more magic and he did the bore and fit my pistons. I got low 90s HP & TQ when it was 88 100+ & 100+ now. My bike is a Dyna so your results may vary
ide really do the 95" kit now,its not alot of coin compared to taking it down a second time.a nice build we do alot of is:
95" kit
1.900/1.615 mild headwork set @ 9.8-1
S&S 570 cams
this is a build that will yield close to 100hp(105+with a stage II type port job) & 100+tq,with stock like driveability & reliability
95" kit
S&S 570 cams
There are several good combinations.
More than happy to sit down and discuss these with you.
Just give us a call..........
Scott
95" kit
S&S 570 cams
95" kit
S&S 570 cams
With our proprietary 98" piston kits, we can pull the 8.5cc dome around, as need be, to optimise the compression of many cams, assuming the 85cc chamber volume.
3 things occur then;
1) the engine jumps up 10 CI.
2) cam is chosen for the intended riding.
3) the compression is then set for the cam.
We have done this many times for clients thru the mail, as well as in-house installs.
HUGE bang for the dollar spent.
Scott
Scott
Since you are not looking not looking into a big bore kit. The cam would be the first thing to look into. We completed a build like what you are looking for. Basic and easy made great power. Stock 88 inch with the andrews 48 cam install. No head work basic ex system. End result was very impressive for only a cam and tune.
Yes you can get more power with other work, BB kit heads etc.. however you have outlined what you want and here is an example of a simple upgrade. Fromt eh cam on up its more dollars to get more power. I have to say I was impressed with how well the 48 cam did in a 88 inch engine. Pulled very nice great power, best of all was a very low cost upgrade.
