Houston area cam tools
Old 12-30-2012 | 01:44 PM
DirtyD1833's Avatar
DirtyD1833
Default Houston area cam tools
Swapping cams on my 01 E-Glide, does anybody in the Houston area have a set of the inner bearing tools to remove/install that they would be willing to rent or loan? Thanks...
Old 12-30-2012 | 02:47 PM
jcb1975@yahoo.com's Avatar
jcb1975@yahoo.com
Auto zone or the likes will loan or rent for small fee. Blind bearing puller is what you need. I bought one from eBay for $60.
For new bearings you put in freezer over night and use old cams with wooden mallet, lots of prelube and tap until they don't go anymore. Worked for me
Old 12-30-2012 | 10:43 PM
djl's Avatar
djl
Have done it this way many tiimes before I did enough to justify buying the tools. Only thing I would add is that the bearings go in with the numbers facing out. The only problem with the AtuoZone puller is that sometimes the right size collet for the .875" bearings is missing; check that before leaving the store.
Old 12-30-2012 | 11:08 PM
DirtyD1833's Avatar
DirtyD1833
Managed to find a puller at AutoZone, some have them and some dont, the bearings are almost too big for one and to small for the largest, but hit it at just the right angle and out they came! New inner bearings are in the freezer waiting until I can get my old cams pressed out and new ones pressed in...
Old 12-31-2012 | 01:35 PM
djl's Avatar
djl
Why wait, unless gear drive, no need; use the oven/freezer method.
Cams in freezer overnight, bearings in oven at 300* for 20 or 30 minutes; bearings will drop right on to the cams. Let everything cool.
Cams with bearings in freezer overnight; cam plate in oven same as above. Cam bearings will drop right in to the cam plate. Two cautionary notes:
1. make sure you have the timing dots marked and aligned when you drop the cam assembly into the cam plate, if not aligned, pull them out before everything cools and you have to press the bearings out.
2. Remove the plug from the top of the cam plate; it has an o-ring that will melt in the oven if you forget to remove it.
Of course, assembly lube on everything. Open the link and go to the 1550 BB/SS 510 Cam install. It is a photo documented step by step how to.
http://harleyhog.host.sk/
Old 12-31-2012 | 01:40 PM
DirtyD1833's Avatar
DirtyD1833
Only waiting for the bearings to get here, was going to do they freezer oven method, but have a press available...
xtremeskier97
03-10-2019 11:22 PM
SiggerTX
Engine Mechanical Topics
01-03-2016 10:22 PM
King of beasts
02-14-2014 10:59 AM
bigdog1949
11-19-2013 10:51 AM
Taterdog
11-11-2007 09:50 AM
