Sponsored by: Jekill and Hyde
Sanity check: Can't/shouldn't dyno tune when it's raining?
Old 12-19-2012, 06:20 PM
Keithhu's Avatar
Keithhu
Keithhu is online now
Received 5,600 Likes on 2,723 Posts
Default Sanity check: Can't/shouldn't dyno tune when it's raining?
Folks - True? False?
Old 12-19-2012, 06:47 PM
pjchamp's Avatar
pjchamp
pjchamp is offline
as long as the dyno isn't in the rain, then their shouldn't be any issues
Old 12-19-2012, 07:01 PM
INDEPENDENT_1's Avatar
INDEPENDENT_1
INDEPENDENT_1 is offline
I tune when its raining outside. Doesn't make any difference in the tune IMO but your numbers may suffer a little on the dyno sheet.
Old 12-19-2012, 07:31 PM
pjchamp's Avatar
pjchamp
pjchamp is offline
don't they have correction numbers for the weater?
Old 12-19-2012, 08:02 PM
INDEPENDENT_1
Yes, they do but the closer the correction factor is to 1.00 the better IMO. Also water doesn't burn and if it's raining, water gets drawn into the combustion process which eliminates room for hydrocarbons and oxygen which are the ingredients for making power. The best conditions for tuning are the same as the best conditions for racing. Cool, dense, dry air makes the best power regardless of a correction factor.
Old 12-19-2012, 08:31 PM
pjchamp's Avatar
pjchamp
pjchamp is offline
oh ok, yeah i knew the better it was to 1.0 the better
Old 12-19-2012, 11:01 PM
stevequad's Avatar
stevequad
stevequad is offline
Nitros doesn't burn either. But a little water in the mix really doesn't hurt, slows down the burn, even helps eliminate detonation and remove carbon. Cold rainy climate is heavy with O2, should produce slightly more power.
IMHO.
Old 12-20-2012, 12:00 AM
INDEPENDENT_1
IMHO.
The oxygen (in nitrous) mixed with hydrocarbons (raw fuel) burns. That's why nitrous works so well, it's introducing extra oxygen molecules into the combustion process and in turn you have to add extra hydrocarbons (fuel) to keep from causing a lean condition. I have studied combustion chemistry in depth and I operate a dyno for a living and the notion that rainy weather makes more power is just plain wrong. "Slowing down the burn" is not good for power nor does water "help eliminate detonation." Setting the quench helps create a homogeneous mixture of oxygen and fuel and condenses the molecules so the flame jumps from one molecule to the next rapidly when the spark plug ignites the charge(of oxygen and fuel, not water). Water would only slow that flame down and take the space that other oxygen and hydrocarbon molecules could be in and be burned so how the hell is water good for combustion/power? Everytime I get water in my gas, my bike runs like ****. Here's something to ponder, why do you think bigger engines make more power? The answer, they can burn more fuel and oxygen. Why do people put on air cleaner and pipes and cams and bigger valves? To get more oxygen and fuel in and make more power. Why do engines with blowers make more power? Because you are filling the cylinders with more oxygen and fuel, not water.
Old 12-20-2012, 01:38 AM
stevequad's Avatar
stevequad
I have used water injection on my turbo engines, with excellent results. But that was in the past, and I am no longer building(retired). I respect your opinion and judgement, as I never ran a Dyno. Just an old mans experience with old school results. I had water injected into carbs when pressure built in manifold using a pressure retard switch. The more water the better, as long as it didn't put the fire out. OTOH these were in race boats, not bikes. But air, fuel, compression and spark are basics. The atomized water most definitely helped reduce detonation and slow the burn.
Still my opinion only because I no longer have documentation, or the education to substantiate this opinion.
Thanks for your information, I really do not disagree with you, just another point of view.
Check this for more info...
http://www.audiworld.com/tech/eng80a.shtml
Steve
Old 12-20-2012, 05:16 AM
Keithhu's Avatar
Keithhu
Bottom line is my dealer wont tune a bike when its raining out, presumably due to the high humidity.
Quick Reply: Sanity check: Can't/shouldn't dyno tune when it's raining?
