cam choices
cam choices
i plan on tearing down the black bitch after the first of the year for cosmetic and performance upgrades. i plan on boring the cylinders to 95-98, also plan on porting the heads and adding cams, along with new intake and thunder header. i've narrowed my choice for the cams to the andrews 37, 54, and 55. was wondering what's everyones opinion on each and what would you recomend.
thanks
paul
thanks
paul
TMan 555 Torkster or 590, S&S 570 or 585. But not knowing how you ride, hard to be definitive. The new Andrews 57 might be a better choice than the other Andrews cams you listed but I don't think it is available for '06 and earlier models. It is identical to the 37 with more lift. The 37 is probably the best all around cam available for a 95"/98" build; certainly one of the best. You might consider the 37 with a set of 1.725 ratio rockers. Not the .560" lift of the 57 but about .535". Just a thought; if you are leaning toward the 37 since you say you have narrowed your choice to the 37, 54 and 55.
Having said that, not knowing how you ride makes it hard to be definitive; riding style would determine whether the 37 would be more suitable than the 55.
If you haven't considered TMan or S&S, you might take a look at some dyno charts before you pull the trigger. JMHO
The Wood 8 will carry more torque out of the gate than the S&S .585, and have the strike of the 6, or .570, but will continue to march out the back door, set-up, and tuned correctly, generally manufacturing 18-20 more hp than the engines cubic inch, up to about 113".
You'd want to run the 8G, in place of the early silent chain/tensioners.
Scott
Scott
