Help! My Cam Support Plate Won't Go In!
Old 11-23-2012 | 04:45 AM
micahpop's Avatar
micahpop
Default Help! My Cam Support Plate Won't Go In!
I'm in the middle of doing a cam install on my '09 Rocker and everything's been fine but I can't get the cam support plate to go in all the way. The distance from the back of the oil pump to the front of the plate is about 6mm but it's only going in about 4.5mm. I can feel that there's metal to metal contact somewhere and my suspicion is the shoulder on the crankshaft but I'm not sure.
I have little experience with Harley engines (or any motorcycle engines for that matter) so speak to me like I was an idiot - which I might be.
In all the videos I've watched, the plate slides in easy as pie. What did I do wrong? Please help.
Old 11-23-2012 | 08:07 AM
jrgreene1968's Avatar
jrgreene1968
probably hanging up on oil pump. i prefer to unbolt oil pump from cam plate , install oil pump, then slide cam plate on.
Old 11-23-2012 | 08:27 AM
ajayrk's Avatar
ajayrk
Pump gears out of alignment where they slip over the drive flats on the pinion shaft.
One other thing, be sure to install new o-rings on the pump neck and cam plate; othewise you may end up with wet sumping.
Old 11-23-2012 | 07:16 PM
micahpop's Avatar
micahpop
Thanks a lot for your help guys. It turned out to be a lifter that was a little low just hitting one of the cam lobes.
MFJones
Milwaukee Eight (M8)
03-25-2019 09:16 AM
lopoko9724
2014-2023 Touring Models
01-04-2018 11:32 PM
Neil
10-14-2008 10:22 AM
jorswift
Oil Archive (no new posts)
06-26-2007 06:59 PM
HDF Tech
Engine Mechanical Topics
01-30-2006 06:30 PM
Quick Reply: Help! My Cam Support Plate Won't Go In!
