100 hp EVO update
Old 11-20-2012 | 11:55 AM
criccio's Avatar
criccio
6th Gear
Default 100 hp EVO update
just got the heads back with new 194 intakes,and the port and polish job completed,flow test was impressive went from flowing 145 cc stock to 200 plus after port and polish.Total lift on the cam with the 1.675 roller rockers came in at 603 total lift,thanks for the input starting to come together.also added the thunderjet to the s&s carb. final assembly this weekend still waiting on some of the chrome to come back.Thanks again for everyones input.can't wait to c if we hit the 100 mark.Special Thanks to Palmer Bro's.
Last edited by criccio; 11-20-2012 at 01:23 PM. Reason: need to add a special thanks
Old 11-21-2012 | 05:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What did we do this time?
Old 11-22-2012 | 07:41 PM
criccio's Avatar
criccio
6th Gear
Default to hillsdale cycle
Thanks for the info on the thunderjet,bought 2 just in case.
Old 11-22-2012 | 07:43 PM
criccio's Avatar
criccio
6th Gear
Default to hillside cycle
Old 11-22-2012 | 08:06 PM
3408pete's Avatar
3408pete
Whats the thoughts on going bigger stroke with a evo??If 100 horse can happen then where could you go with bigger inches??I had plans of going big inch with mine to try and hit the 100 horse mark maybe a little more if it would happen
Old 11-23-2012 | 08:06 AM
n2ofaster's Avatar
n2ofaster
getting over 100 hp is not all that difficult. we did it back in the mid 90's and won some daytona shoot out in the process. it takes a good selection of parts, cams , heads carb etc. The biggest problem we see is that people have a tendency to over cam the motors, not the correct ompression and heads that are ported out to big for the job. If you figure out the air required for a 80" motor to make that power the heads only need to flow 140 cfm @ 10". Anythng over that is overkill and will slow down the air speed to completely fill the combustioin chamber. Bigger is not always better. dsv
Old 11-23-2012 | 08:33 AM
3408pete's Avatar
3408pete
I was hoping Hillside would chime in to-----------------need lots of ibput because its getting tore down as soon as I find a cheap used streetglide
Old 11-23-2012 | 08:59 AM
grbrown's Avatar
grbrown
Wink
Stroker kits are available that will give you 89". If you want more info pick up the phone and talk to Scott at Hillside. Also visit their website where there are tempting packages set out!
Old 11-25-2012 | 12:01 AM
3408pete's Avatar
3408pete
yeah have looked all ready and talked to several in the area that have gotten bigger than 89 cubes.-----------------I was just hoping someone would chime in that had done this with actual dyno sheets .For example a a 80 cube 100 horse that had moved up to 89 and ???horse
Old 11-25-2012 | 03:50 AM
grbrown's Avatar
grbrown
Cool
I went to an 89" stroker and then wanted more. That is getting into territory that is pushing the envelope of what can be done with an Evo, without replacing crankcases, for example. They are not as robust as TC cases and don't take kindly to being bored out. The stroker crankshaft required a new crank, bigger bores requires new cylinders, plus new cases, plus building the darned thing, which gets you into new engine money!
The answer to your query is to do as I did and buy a new one! An S&S 107" in my case.
For more info on how practical it is to make an even bigger Evo, phone Scott at Hillside.
Big Dave
EVO
10-27-2015 07:44 AM
drf7728
EVO
03-25-2013 09:20 PM
angrydude
EVO
11
12-23-2012 11:53 AM
94 Heritage Classic
02-13-2009 05:37 AM
juspasnthru
09-05-2008 03:58 PM
Quick Reply: 100 hp EVO update
