96" to SE 103" kit upgrade. Compressing level question.
I am upgrading my bike to the SE 103 bb kit (29903-07). I am not sure what the compression level is with these jugs. My heads are SE part# 16500013a which are supposed to offer same compression same as stock heads just cnc ported. I am adding an Andrews 54h cam as well and not sure whether I should buy the SE 10.5 compression pistons as well for this combination. Any info would be great. Thx
IMO .. If you stay with the pistons in the kit? Use Andrews 57.
10.5 pistons,use the 54's.
if you already have the 54's then you could surface the heads .030- .040 and be where they like to be.
Any machine shop can set this up,and resurface your heads. It dosent have to be a Harley performance ,special type of thing.
I have seen a Lot Of these 103-107 54 cam bikes. They always feel better if you can get the compression bumped a little.
Don't get me wrong , it will work good as your asking. But the little extra compression really helps.
That's why Andrews made the 57 , for the factory 103's.
If you pull the heads. Your back to making the 54 work
sorry. yes if you have the heads off use the .030 gasket.
Kuzmitch Davidson
Engine Mechanical Topics
04-09-2018 09:23 AM
