Dyno on carbed baggers
Old 01-28-2007 | 01:10 AM
apachethunder03's Avatar
apachethunder03
Default Dyno on carbed baggers
I've been seeing alot of posts on dyno charts for fi models. How about charts oncarbed models. I have an 03flht carbed. Getting 70.1hp and80.8tq. SE a/c, SE slip-ons, carb jetted(don't remember which jets)only that I followed the instruction sheet.Again, would like to compare carb to carb on this post. Notsaying that efi can't comment, but would like apples to apples lolAlso have 510g's on the way. And will probably do a 95" next yr. Heads arequestionable still. Wonderhow the 510g's will result in the dyno.
Old 01-29-2007 | 09:01 AM
dynomec's Avatar
dynomec
Stage II
Default RE: Dyno on carbed baggers
You can go here to get all information about dyno.
www.dynomec.com
Old 01-29-2007 | 06:49 PM
04RoadKing's Avatar
04RoadKing
Your #'s look pretty good for just having A/C kit and slip-ons. When my RoadKing was still a 88" with a Set of S&S 510G Cams and a S&S super E Carb, along with Rinehart True Duals I was at 74.6 HP & 86.3 TQ. I don't have the Dyno chart handy to show you. But by the seat of the pants I could tell it had alot more low end TQ and would pull a lot harder then it did with thestock Cams, and Stock C/V carb with the SE A/C.
Old 01-30-2007 | 12:36 PM
SUPER01's Avatar
SUPER01
I had my 2001 Superglide on the dyno last year to tune the carb for the right mixture.
I installed Cycle Shack slip-ons and a Big Sucker AC.
It was running rich from when the indy shop installed different jets and a Yost Power tube.They always go withthe same jets with what I installed from what they told but every bike is different. First run was 65 hp and 73 tq.
Once it had the correct jets in it made 69 Hp. and 77 Tq.
Only charged me$65 and Iwas in the dyno room the whole time, it took 1-1/2 hours.
Old 01-30-2007 | 12:48 PM
glideridemike's Avatar
glideridemike
What is the 88 rated at, say in 2003?
Old 01-30-2007 | 01:35 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: glideridemike
My 04 Bone stock at the rear wheel 59HP & 70TQ
Old 01-30-2007 | 11:07 PM
apachethunder03
Thats what I'm hopping for, alot of low end tq. I think I am starting to understand the dyno charts alittle.
Old 01-30-2007 | 11:10 PM
apachethunder03
When my bike was stock I had it dynoed just so that I could see the improvements as I went along. It had 61.4 hp and 73.0 tq. The dynorun was just that, no tweeking just readings.
Old 01-31-2007 | 10:24 AM
glideridemike
And an 88 is the same in stock form whether its in a bagger, sporty or dyna, correct?
Old 01-31-2007 | 01:33 PM
04RoadKing's Avatar
04RoadKing
No, a Sporty is not a 88" the Twin Cam 88" = 1450cc The Sporty's are 883cc or 1200cc
Quick Reply: Dyno on carbed baggers
