infamous carb spit w/new twist
Old 09-17-2012 | 08:48 PM
asterling's Avatar
asterling
Stage III
Default infamous carb spit w/new twist
I have owned 6 big twins and modified several carbs with great results. Just purchased '06 Sporty that spits through carb. Installed S/E mufflers and free flow intake. After several attempts at slow and main jet changes, drilled and undrilled slide, early and current year jet needles, stock and light slide springs, carb still spits at idle during low end acceleration. Took Sporty to
local high performance shop. They could not fix after several attempts. To Sporty well know H-D engine builder with dyno. They dyno'd carb, but said the '06 Sporty ignition module has retarded timing at idle rpms. They say fix is after market adjustable timing module. Carb still spits. Any ideas or input regarding carb spit or aftermarket module. Thanks in advance, Santino
Old 09-18-2012 | 06:00 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
What jet sizes are currently being used?
Scott
Old 09-18-2012 | 07:08 AM
JohnnyC's Avatar
JohnnyC
Could it be do to pressure from a valve not seating correctly?
Old 09-18-2012 | 08:41 AM
n2ofaster's Avatar
n2ofaster
IMO it s the idle air circuit that needs to be adjusted. 2 1/2 turns out is good starting point. dsv
Old 09-18-2012 | 10:27 AM
ajayrk's Avatar
ajayrk
Usually a .45 jet is a good starting place. Next would be a richer needle.
What is current needle number?
Also check for intake leaks at the head to manifold connection. If it has been sitting for a while the may be dry rotted.
Khshockey44
02-10-2013 01:15 PM
883Frankenbike
01-19-2013 11:17 AM
asterling
09-18-2012 12:01 PM
chaswood
Carburetor Related
07-02-2012 01:57 PM
fatboy2006
06-20-2007 10:32 AM
Quick Reply: infamous carb spit w/new twist
