Air filter question
Air filter question
This morning I started up my bike for a ride and as I pulled out of the driveway I had no power. Tried to roll on the throttle and nothing. Engine still running but no power and the check engine light came on. After about 20 seconds I got the slightest bit of power when giving it full throttle. Shut the engine down and let it sit for 30 seconds, started it back up and had full normal throttle and power. Rode for an hour and no problems. For some reason my thought was maybe I was not getting enough air flow into my air filter. Took it off and found it a little bit dirty but not bad. But what I did notice was a greasy film on the gasket and on the inside plating of the air filter.
Is this normal or is it a sign of a bigger issue?
Also noticed the 2 lines feeding into the air filter had a greasy film on them as well, especially the one on the right.
Thanks
John
Thanks
John
Thanks
John
Thanks
John
Your throttle problem could be a dirty TPS, throttle position sensor. You failed to mention what model, EFI or carb, modifications, etc.; I have assumed EFI. There are ways to test/check for voltage and if you have a fuel management system that allows data logging, you can check that way as well.
sblaiz@hotmail.com
03-08-2020 01:55 PM
Cruzn34
03-25-2013 02:55 PM
