Cams for a 2011 FLHTK with a 103 Twin Cam
Dealership quoted me the following prices:
SE 255 for $526 for cams and other parts needed (parts only)
$1036 for parts, installation, dyno and out the door
Woods Tw555 $685 for cams and other parts needed (parts only)
$1185 for parts, installation, dyno and out the door
They also gave me some dyno sheets of similar bikes they had done each cam jobs on (same intake & exhaust as mine) in the last few months so I can see what I might expect. They claimed I should expect to be running mid 90's HP and 110-115 Torque with either cams, but would have a different power curve depending on which set I chose.
Anyone think these prices are off base or have a recommendation about which cams they liked better?
My riding style to be a little heavy on the throttle, grabbing gears at about 4200-4500 RPMs.
Thanks in advance.
Thanks in advance.
ouch seems costly. I kept going back/forth between the 255 and andrews 54h. I bought the 255's then sold them and went with the andrews. Better/easier start ups and a little more power band. I went with adjustable puchrods and had a tech do the install at his house after work. I had the bike tuned,but that's another story. I almost got 100/100 to the wheel.
I was looking more for a torque cam to move my road sofa. Good luck.
What ever you do- make sure to get it tuned right.
+1. I would not run the 255 in a 103" configuration.
I'm thinking I'll go with a different option, the551CE Easy Start Cams from S&S. The stealer will do it if I want them too but they are not stocking them. An indy in my area is doing good things with them and they seem popular with 2 of his customers I spoke to. One of those guys has had them for a few months and rides 2 up with a trailer and has lots of low end TQ, so he said.
I have a buddy (MMI grad and 14 year HD tech) willing to help me install at his home/ shop and the indy will dyno/ tune after.
Before I do, I'll look at those cams too Bagger and Hillside...thanks for the replys.
Might be ready to do this mod this coming January.
