I want to remove my cat from 2011 RG
Picked up my 2011 RG Ultra and trying to not get crazy like i have before with all the exhaust/intake/tuner/etc costs...
Since this model has the cat it seems that there are companies out there (per talks at sturgis) that will take my exhaust and "gut" it out if i send it to them. does anyone know of a company or place where I can send them?
I know it seems cheap but V&H wants almost $700 for a header pipe and I'd rather same $ and put it into slip ons. Not the most power I know but i will not go to a 2into1 exhaust...I love the look of two mufflers below my bags...
any help, input, two cents from you guys would be appreciated!
thank you.
thank you.
two ways to do it/ fullsac performance.Google it- option 1. option 2 i removed my stock head pipe,cut it in1/2 right before the 2-1 split to the left muffler. removed the cat. Welded the pipe back together. Under the heat shield-you would never know it's gone. Fullsac will do this to , with a core charge.
It's a great mod and helps reduce the heat-BIGTIME
