gear cam change crank run out
was thinking of changing the cam in my 2002 to a gear cam.... i was told the 2002 were the last year with the timken bearing and forged crank..etc.. are the 2002 twin cams more receptive for a geared cam because of this? should crank run out still be checked even on the 02's?
I just installed mine w/o checking my runout a year and a half ago at 81,000 miles, ( same crank set up as yours.) Bike's now got 113,000 and runs like a top. And I've never even heard of a early TC having a runout issue, the Timken Lefty bearing is just that good.
Having said all that, for the little effort it takes why not check it? You're gonna' be in there anyway!
true... what cam did you end up going with? notice less drag in the drivetrain any?
the main reason is having less down time.. not to open her up check it and then determine what cam design to use and then order... and re-open her back up..etc..
My bike came with the 95" Big Bore kit. and with it's higher compression vs the 88" the Andrews 26G were the best choice for me. HP mid 80's, TQ mid 90's and still starts easily and gives 46 mph. ( Same "feel" as before, just way more of it...I love it.)
On an 88" Andrews recommends the 21G.
