Spark knock
It has always been my understanding that all Delphi systems have incorporated the ionization knock detect system right from the start.
Two things to note: Changing any perimeter like spark plugs or plug wires can mess up the detection system, making it either perform poorly or become inoperative.
Stick with recommended HD plugs and wires. FWIW Fastrider 124
Champion RA8HC
ohms while most other resistor plugs are 6k ohms and here's the problem. Plug and plug
wire need to be about 25k ohms for the ion knock detection system to work and retard
the spark when ping/detonation occurs. Other than indexing, I've seen zero improvement
using more expensive plugs including high performance iridiums in a Harley even though
they do show improvents and are stock in modern high performance vehicles. IMHO.
Ion sensing system
to always work that way. Several guys I know were able to fix their pinging problem with an
oil cooler on their baggers - desert southwest is smoking hot today.
