Need help on cam plate upgrade
Hopefully someone can answer this for me. I am currently doing the cam conversion upgrade on an 01 road king using the current 25355-06A cam plate with 62400001 S/E oil pump and andrews 26n cams. I have a question about the crank bushing (spacer) that was originally between the crank sprocket and cam plate. I see no reference to it for the 25355-06A cam plate and need to know if it is used on a conversion of an older bike.
If that is not the spacer you are referring to, please identify the one you are asking about.
Right, everything runs in the parent material of the plate; not the best way to design a cam plate but saves the MoCo $$$$.
Right, everything runs in the parent material of the plate; not the best way to design a cam plate but saves the MoCo $$$$. And if you don't like that setu, the MoCo will be happy to sell you the SE billet plate which BTW, does have bushings.
Iron lHorse
Exhaust System Topics
12-13-2013 11:45 PM
