04 RK need more power, 95" SE or 97" S&S?
Old 06-28-2012 | 10:47 AM
danosrs's Avatar
danosrs
Default 04 RK need more power, 95" SE or 97" S&S?
Like to hear pro's and Cons? I have used S&S in the past and really would like to go with their 97" inch kit with S&S super E and was hoping to hear from those who have both 95 SE and 97 S&S??
Old 06-28-2012 | 03:39 PM
JohnC FXDX's Avatar
JohnC FXDX
No need to limit yourself to those two. You can send your stock cylinders off to any good engine builder and have them bore them and match pistons to it. You can even go 98" no problem. You also don't need the super E carb unless you are planning on going with a radical build. The stock carb can handle a basic big bore. Needs a little tuning, but it works. Hillside Cycle and Vee Twin performance are two ships offhand. Both forum sponsors and I'm sure they will chime in soon.
Old 06-28-2012 | 06:32 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
JohnC, is correct in regards to the carb,
The OEM CV, is certainly a VERY good carb.
Don't get me wrong, as we embrace S&S carbs, and purchase a TON of their products from them.
What I will also say, is that you can bore your existing cylinders to 98".
We have been doing 88-98", and 96-107" builds now, since 2007.
No worries whatsoever.
Combine the proper camshaft, for your riding wants/needs, along with a matched head to optimize the cubic inch increase, and cam, and you'll be quite surprised, as to the outcome.
We are only more than happy to lend a hand with your power up-grade.
Scott
Old 06-29-2012 | 07:16 AM
prodrag1320's Avatar
prodrag1320
by all means go 98",we`ve done 100`s,in mild or brutal builds
Old 01-20-2016 | 12:21 AM
zxport123's Avatar
zxport123
Hey Kirby what is a brutal build for a twin cam motor at 98 inches?
ButtMan1000
11-04-2012 10:34 AM
05 Wd Gld
03-07-2007 10:56 PM
bjornsson
09-21-2006 03:03 PM
bjornsson
08-23-2006 06:46 PM
cwilks
08-23-2006 03:25 PM
Quick Reply: 04 RK need more power, 95" SE or 97" S&S?
