knocking
knocking
I have a 93 Fatboy, when i bought it from a private owner it had a knock under torch, I just had the carbs rejetted, it runs better but the knock is still there. I put an after market air cleaner and it also has long shot pipes and cams. Any input on what I can do to fix this. I was told that a ignition module would fix it, if so what would be recommended.
RE: knocking
The knock or ping I should say only happens when I go up hill or get on the gas. I guess knock was a bad choice of words. Its more of a pinging thats why I had the carb rejetted. The mechanic who rejetted it said if it still pings I should get an ignition module. I want to get some advice from this forum.
Thx
Thx
RE: knocking
Ok, yeah. Have you tried using higher octain gas or octain booster?
The ignition should help also. Sounds like maybe you might have a Higher compression engine then stock. If that's the case you may already have the ignition. Just find a good dyno tunner to have them tune it. Alot of the times the pinging is from a build that was not match with the proper parts, compression, pistons,cams, heads, carb, ignition, pipes, and tune. Good luck.....
papaduke187
01-25-2017 11:30 PM
