Disappointed in new cams!
Old 02-23-2007 | 03:16 AM
RBJones's Avatar
RBJones
Default RE: Disappointed in new cams!
ORIGINAL: trigger1911
Just got my bike back with new Andrews tw37B cams installed. The feel EXACTLY like the stock ones! No difference whatsoever. Please tellm me I missed something and didnt **** away $500! Help me before I buy a Honda!
I'm not familiar with the 37 cams, but is it possible that they don't start coming on until you get to higher rpms? If so, you won't feel any difference at lower rpms and you're likely to actually lose torque over stockat the lower rpms. Try reving higher when you shift and you may feel the power band coming on hotter than stock.
The 21 and 26 cams are designed for 88 or 95 engines with fairly low to stock compression and they work well in the 1800-3500 rpm band where most of us spend our time. Most people with these cams can really tell the difference in their low-end torque over stock cams.
Hope you work it out.
Old 02-23-2007 | 08:32 AM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: fxstb00
butr wanted to add that all the replies talk about the tw37g cams, this guy had the tw37a cams put in, chain drive. is there a big difference in power made between these two cams?
The only difference is that the gear drive cams are more accurate for timing, and you get rid of the cam chain tensioners. Some say that the gear drive cams end up with +4 HP/torque over the chain version.
If you can't afford the gear drive, do the chain drive.......but try to do the gear drive to avoid any hassles later on.
Steve
Old 02-23-2007 | 11:44 AM
ButtMan1000's Avatar
ButtMan1000
ORIGINAL: RBJones
Here is the run chart on my 2003 FXD with the 37G's. Torque is fantastic at mid-range!! No loss at lower RPM's either, even riding two up.
88 C.I.
stock compression,
stock CV, re-jetted
SuperTrapp 2:1 exhaust
SE Stage 1 AC
[IMG]local://upfiles/20717/A18294A52EAB490098AB5FA2A1667F06.jpg[/IMG]
Old 02-23-2007 | 03:44 PM
HOGWYLDPR's Avatar
HOGWYLDPR
I am installing 37G cams in my Deluxe this weekend. The bike is stock except for Zippers stage 1, Mikuni, SE ignition, 3.37 gearing and Thunderheaders exhaust. I am going to use Woods 4* advance key in order for these cams to come on a little sooner. I hope to at see at least 90/90 when it's all done. If I can't get the Thunderheaders tunes I may go to the D&D Fatcat.
Old 02-28-2007 | 04:44 AM
DADIBLU's Avatar
DADIBLU
PhilM,
Do you have a dyno of your current build? I was about to go with the 37g on my streetglide, but now i'm thinking twice. Trying to get a build that has a lot of torque all around, as I'm no light weight. I've been runninga SE Stage II with the 203's, SERT, and some python slip ons. Need a little more umph, because I'm tired of having to drop a gear to catch up with my group.
Thanks
Old 02-28-2007 | 02:27 PM
RBJones's Avatar
RBJones
ORIGINAL: DADIBLU
PhilM,
Thanks
Sounds like you need a cam that will perform better at lower rpm like the Andrews 21 or 26. They start building torque at 1700-1800 rpms up to about 3500 rpms, which is the band most of us operate our Harley in. A common mistake people make when selecting cams is that go for the all out torque & horsepower ratings. These are great for drag racing. Problem is, hot cams don't come on until you reach over 3500 rpms, which means you've got to be doing about 75-80 mph in 5th before you get any umph. That means you'll be shifting a lot between 4th and 5th on the highway at speeds lower than that, esp on hills. And it also requires you to rev up your engine more in each gear to get the pull you're looking for.
I'd take a look at the Python's, too. If they're loud they probably hurt you at low rpms where the proper back pressure is needed to keep the exhaust from sucking out some fuel mixture. You're better off with something like the Supertrapp SEs. Read articles by Joe Minton in American Rider. He does an excellent job of explaining the torque band issue.
Old 02-28-2007 | 08:07 PM
PhilM's Avatar
PhilM
ORIGINAL: DADIBLU
PhilM,
Do you have a dyno of your current build? I was about to go with the 37g on my streetglide, but now i'm thinking twice. Trying to get a build that has a lot of torque all around, as I'm no light weight. I've been running a SE Stage II with the 203's, SERT, and some python slip ons. Need a little more umph, because I'm tired of having to drop a gear to catch up with my group.
Thanks
Sure do.... It's pretty strong. I went with RevPerf 98" jugs & pistons, Head-Quarters Heads, and HQ-0039 cams. I also have a Dakota Kid 48mm TB, but Doug Coffey @ HQ tells be that it's too big and is actually costing me some torque. I also went with a very conservative 10:1 CR. Now I'mn wishing I had followed Dougs recomendation to build it @ 10.5:1. I was gun-shy from a previous bad experience with 10+:1 CR. Oh well.... live & learn. But it's still BY FAR the best I've ever had.
The same results are attainable from a properly built 95". (follow Doug's direction)
[IMG]local://upfiles/8665/FD0A79D4B43E400EAFDBA195833E8241.jpg[/IMG]
Old 03-02-2007 | 03:06 AM
DADIBLU's Avatar
DADIBLU
ORIGINAL: RBJones
ORIGINAL: DADIBLU
PhilM,
Thanks
Thanks RBJ. Your right about thepython's. I'm ditching themfor a Rinehart 2-1. I've considered the 26g, but I've seen someposts fromfolks who have them say they feel a loss on the top end. Right now, the torque starts to climb at 2500, peaks at 3500 and starts to roll off at about 4000. I can feel it when passing on the freeway, and it's even worse riding 2up. I'm looking for a build that has good torque all the way across. I saw the 100/100 TC95 on nightrider.com and got me on my quest.
Old 03-02-2007 | 03:12 AM
DADIBLU's Avatar
DADIBLU
ORIGINAL: PhilM
ORIGINAL: DADIBLU
PhilM,
Thanks
Looks like it must be a kick in the pants to ride!! I've seen a lot of good posts about HQ, so I'll definitely be pinging Doug.
Thanks!!
Old 03-02-2007 | 03:18 AM
DI75's Avatar
DI75
I have never ever felt a differnce beyond the stage 1 upgrade until I did the heads!!! The bike needs to things to create power. Air and fuel. Do the headwork, then you will notice the difference!!
Quick Reply: Disappointed in new cams!
