Fatboy Breakdown...please help!
I was looking for electrical troubleshooting on the internet and found this site. I'm hoping someone can help me with an electrical problem I had this weekend. I was driving to a pre-Sturgis rally on Sat and the temp was about 95degrees. Out of nowhere the bike just shut off. I pulled to the side of the road and it started back up. It did this a few times but the last time it wouldnt fire at all? I had no spark to the plugs so I trailered it home[:@]
Any advice on where to start would be appreciated.
Thanks,
Jeff
Thanks,
Jeff
RE: Fatboy Breakdown...please help!
You havent given them much info to work with, dude
You should probably post the year of the bike, whether its EFI or carb, and any other
after factory modifications that have been done to the bike
so the guru's have some info to go on besides the model.
Being that you have a stroker kit I am also beting you have a aftermarket ign module in the nose cone. Many of these go south do heat. You will see many with the cover on there, they also short out against the cover, again the reason for the cover off of most bikes. Coils are not that common, but the ign is I would even hedge the bet further ans say you have a crane HI4 in the nose cone.
If your ignition module is plug and play, unplug it, plug back into the stock one, and see if the bike starts, since the light is not on, either the module is bad or you're not getting 12 volt supply to it. Looks like HDwrench was right on top of it.
John TN
John TN
