ACR Troubleshooting Info
I just looked at the sheet and it refers to pin 19 not 15 but this is the sheet I just read so I don't know if it is applicable to you or not. http://www.harley-davidson.com/en_US...ts/-J04441.pdfMaybe I am reading it incorrectly?
I used the -08 kit so I have the 04441 instructions. Is it possible that the enabling feature is now routed to cavity 19 due to some engineering reason and zippers is following hd's lead on this? I guess you will find out when you call zippers. Good luck, I'm sure you will figure it all out.
I never finished hooking mine up last year. I do plan on getting mine running this year and with out the help of HD and their parts and reprograming of the ECU.
Here is a timer that I will use http://www.dynotunenitrous.com/store...?idproduct=107
I'm going to wire the timer into the starter relay with a relay switch controlling the ACR solenoids
qtrracer: thx for the link. I now know how much time to run now.
This should work. Just so you know I have wired the ACR's into the starter relay and the bike wont start. if your thinking about trying that route.
Here is a tech tip from HD that has some of the info you were looking for https://www.box.com/shared/ylloapgfue
My bike is an 08 dbw tourer so that is why I used the -08 kit and corresponding 0441 instruction sheet. I didn't know if you are dbw or not. I am sure that is the diff between 1 set of instructions in the -08 kit and the other set of instructions in the -06 kit for the cable operated throttle body equipped models.
Mastertune Question
When plugged into a Screaming Eagle Pro Race Tuner there is a window that has a box that asks the operator to "enable automatic compression releases?" and there is a box that is default checked to no, you have to check yes. My guess is on a T-Max you will have to plug it into your computer just like you were going to do some tuning and find the area/window that has the "enable automatic compression releases?" and enable them. Other wise just wiring them in as per instructions only gets them ready to be enabled.
This is the closest thread to my question: does the TTS Mastertune tuner have the same feature to enable the ACR that the SE Pro Tuner has? The dealer near me uses the Mastertune device, so I plan on getting one soon. I'm adding ACR heads with porting work from Hillside Cycle to my 96" to 103" conversion and have the ACRs and the overlay harness yet to install. Thanks in advance.
Another Option?
Just installed the Stage IV kit from my wrecked (deer at 100+) '08 FLTR into my new-to-me '08 FLTR. ACRs aren't working. Have any of you guys thought of grounding the V/GY wire from pin 15 or 19, as the case may be, by switch? Is this too simplistic? Is this a stupid option? Any ideas?
