Choke
Old 04-20-2012 | 08:42 AM
bombdogg's Avatar
bombdogg
Angry Choke
My choke will not stay out. It will stay on full choke for about a minute at 1500rpm then it slides into about 1/2 choke and 9000rpm? With it being cool here this is a real pain in the **** I did not think it is supposed to move on its own. Any Ideas?
2003 Dyna Low Rider
Thanks
Dan
Old 04-20-2012 | 10:30 AM
SoonerSoftail's Avatar
SoonerSoftail
If I remember right tightening the nut on the back side of the bracket makes the shaft not slide as easily and stay where you put it.
Old 04-20-2012 | 10:55 AM
bombdogg's Avatar
bombdogg
Thanks Sooner
Old 04-20-2012 | 07:33 PM
DaveCarlson's Avatar
DaveCarlson
To increase the tension on the choke cable you need to remove the cable from the bracket. Hold the plastic threaded area with the correct size wrench and turn the choke **** clockwise to increase the tension. Put the threaded portion back in the bracket. CAREFULLY TIGHTEN THE BOLT ON THE BACKSIDE OF THE BRACKET. I just use finger tight. Otherwise you will break the choke **** lose from the plastic threads. The only cure at that point is to buy a new cable. Don't ask how I know...
Dave
George Tirebiter
07-28-2018 07:59 PM
Jarhead Red
01-19-2013 01:51 AM
Steel
07-29-2009 08:09 PM
DENGUY
03-26-2009 02:21 PM
RonJD
01-27-2009 12:30 PM
Quick Reply: Choke
