monster baffles and big radius
I have a set of big radius pipes on my softail std. I also have a high flow air filter and se racing tuner. My question is if I install the monster baffles will i need to remap the race tuner, and has any one installed monster baffles on the big raidus which part nuber did you use??
RE: monster baffles and big radius
Are you adding baffles to gain back low end power or just to quiet the exhaust some?
My reason was to quiet the exhaust. I had no problems with the power output without the baffles.
I just put Khrome Werks HP drag pipe baffles in my Samson,Rip Saw drag pipes and I couldn't see the justification to re-tune.
The Thunder baffles don't add hardly any exhaust restriction. All theyadd is a pipe reducer and lollipop to each pipe, if we are talking about the same baffles. You can make a set yourself, if you follow the posted directions at the top of this forum under How to drag pipes.
