K&N filter verses Stage 1 SE filter
I see that some dealers are now selling the K&N filter to replace the Stage 1 SE filter. Is there really much to be gained by switching out to the K&N?
Also on the K&N site it says just switch it out, so I take it theres not enough air flow change to warrant a new dyno on it? The ECM would auto adjust for the difference?
Thanks
Thanks
The newer type SE filter is filer glass . You do not oil .
You wash it put it back.
for a long time the oil type like KN was the best option.
But times change the fiber glass provides more flow and filters better. It also saves money on the oil.
On the newer TC103's if you put the SE filter on the flow is so much better you should add some fuel how you do it is up to you.
It was the air flow I was wondering about. I went to the dealer since they sold them $60 and was going to buy one. They said we would be happy to take your money, but to be honest they have dyno'd with the K&N and the SE filter and they said there is nothing to be gained so save your money.
So I didn't buy it, They are going to dyno it tomorrow. I was hoping they would of had it done today but they will only get it all assembled and dyno'd tomorrow
You use the spray on cleaner or pour in the pan, but its only for the outside of the filter, then you rinse it from the inside out and you DON"T use any oil on it. Let it dry and put it back on.
