Unusual Engine Noise
2011 CVO Road Glide.Under full throttle I hear what sounds like marbles coming from the engine area. Bike has 10500 mi. Its only under full throttle and seems to start around 3500 rpm. Bike runs great, just the noise. Any ideas? I know my 88 ci never sounded like this.
Diagnosing noises over the internet is very much a hit or miss proposition, but the noise you describe sounds like pinging to me. It's really not all that unsual and actually quite common.
If in fact that's what it is, the most likely cause is ignition timing. If it's something that you first noticed after fueling up, it could be sub-par fuel. There are other possible causes, but these are the two most likely.
Good luck getting the results with a dealer dyno... hope it isn't typical. Better bet would be to find a reputable indy tuner.
Pinging or detonation... tune is the correct answer either way. The bike will run much better, likely get better mileage, and run cooler to boot I'd imagine.
Roger
Roger
