Advantge of aftermkt backplate vs stock?
guys, I'm in the process of deciding which , A/C ,and pipe combo to purchase this spring, I WILL be gettting the PC111.
So,,,Whats the advantage of say Ness ,SE, or KN backing plate vs using the stock ,
and drilling a bunch of 1" holes in the stock setup w/a K&N element??
ya get so many suggestions here which is great,but still leaves me confused and undecided?! As far as my local shop??!!?? Why do you think I'm here??
grin
grin
RE: Advantge of aftermkt backplate vs stock?
The biggest difference is actually the filter.
THe K&N "stock replacement" filter is about 1" thick and varies in diameter. The filter that comes with the K&N, Ness, S/E "High-Flow" kits is about 2" thick and round. Air flow into the throttlebody / carb is less restricted on the round filters than the stock shaped unit.
