Vapor Lock?
Vapor Lock?
I have a 98 heritage springer 1340 carb. Just got the thing rebuilt about 800 miles ago. When I ride for 30 to 40 miles and then shut it off for a few minutes and get back on it has died on three occassions after running for about 5 minutes. Every time it has died I have been putting around at slow speeds and low revs after the restart. It is like it is running out of fuel. I sit for about 10 minutes put the choke on and off I go. I drilled out the baffels in the diaphram in the gas cap to allow more air but it has did it once since then. Getting ready to leave for sturgis don't want problems. Any suggestions.
RE: Vapor Lock?
It was the engine. Did it again last night. Rode 30 miles shut off for 5 minutes ran great. Rode 30 miles shut off for 1 hour ran great. Rode 30 miles shut off for 15 minutes, started up ran for about 2 blocks and died as if it ran out of gas. Wouldn't start for about 35 minutes then ran great. Puzzled!!!!
RE: Vapor Lock?
O-k if you know how to check and adjust the pushrods properly, this is what I would do first or have someone check it that can, they can loosen and lose the correct lifter preload adjustment especially when they are new. Check this out and let us know what's going on.
John TN
John TN
RE: Vapor Lock?
If you don't have solid lifters, (I'm assuming you don't) then you have hydraulic lifters, hence the never have to adjust the valves. The hydraulic lifters have to pump up to keep the same pressure from the push rods to the valve rocker arms at higher rpms, we are also talking about the push rods, say if they were'nt properly adjusted then the valves will open too far or not enough, throw in more than one out of adjustment and it can cause all kinds of poor engine performance or engine damage. Basically the lifters have a set amount of preload on them from the push rod adjustment. Not enough preload, problem, too much preload, problem.
I'm not saying this is your problem, but it is where I would start looking first, as the adjustable push rods can cause this kind of problem especially when recently installed.
If this is'nt it then it might be an electric problem that when cooled down will function properly, such as a bad coil might do.
First things first, check the push rods. You will have to eliminate one thing at a time until you find what's causing your problem.
John TN
John TN
