Engine stoped and engine check lamp came on
HI,
I have a 09 FXDL and today I had the engine check lamp come on when riding home for about 16 miles. When home checked the manual and said I must take bike to Dealer. I started the bike again, the engine check light came on and of in four second like it always does when you switch the off/run switch to run. When I hit the start switch it fired up good but the engine check lamp came on and off for about 2 seconds. Then I rode to get some fuel and to check if the engine check lamp comes on. The light did not come on but the engine just stoped about 1 mile from home. Rolled down hill to petrol station filled up and the bike started good and rode home. In the last month the bike sometimes strugles a little to start and sometimes sraight away. Could the battry be on its way, and the engine check lamp on speedo gauge means what? I like to fix the problem myself but would like some opinions.
Thanks
Thanks
HI,
Thanks
Thanks
HI,
Thanks
Thanks
It's not the fuel light it had about two litres of fuel when I got to the fuel station. About three hours ago when I got back from the fuel station I tried to start the bike, and wan't start. I will try and work out how to get the service code and will let you guys know what I find .
Thanks
Thanks
I have the 09 FXDL owners manual and the 09 Dyna service manual.
I had quick look and cant find anything about trouble shooting codes. I pushed the black button on the side of the console and only showes A miles, B miles, time, main miles and the tank is nearly full but shows r is low which is the range.
Thanks
Thanks
I have to find what that is unless you know.
Thanks
Found the problem, the system relay was sticky. I pulled it apart and sprayed silicon lube inside the relay and now it starts instantly. Funny thing was there was no corrosion anywhere and for a few months back the bike used to sometimes kick over a few times before firing. The relay switch is metal to metal and must of had trouble closing. I will also carry spare relay's on the bike on big trips. I would have saved a few bucks for not taking it to a dealer.
widerider96
09-02-2014 04:23 PM
