Thoughts before I pull the trigger on this build.
05 t/c88 Roadking with stage1 a/c,510g mackie cams,se exhaust and pc 111 turner installed in bike as of now.78 hp 87 tq
WORK TO BE DONE
88 TO 98 W/ CP 10.0.1 PISTONS DOME CC 3
.030 HEAD GASKET
05 HEADS TO BE WORKED MILD PORT ,VALVES
COMP RELEASES
85 CC HEADS
CLUTCH SPRING IF NEEDED
BIKE WILL BE DYNOED AGAIN
510G MACKIE INT OP. 22 CL 38 DUR 240 CENL98 TDC .194 EXH. OP 52 CLO 12 DUR 244 CENTL 110 TDC .138
COMP CALU. STATIC 10.07.1 CORRECTED 9.33.1 COLD CRANKING 194.1
HILLSIDE KIRBY DJI AND ALL OTHERS WILL THIS WORK WITHOUT PROBELM SUCH AS PINNING etc. I need machine work done also advice on build. SPRING IS COMING. IF IT LOOKS GOOD LET ME KNOW OR IF TOU SEE A PROBELM LET ME KNOW.IAM NOT DRAG RACING CRUISING BUT SOMETIMES I GET ON IT.
WORK TO BE DONE
.030 HEAD GASKET
COMP RELEASES
85 CC HEADS
Make sure those heads are up to the task.
Let us know, if we can be of any help.
BTW, I WAS, on the ice this morning.........jigged up our limit of Walleyes before 9:00, and now, they'll be "swimming" in hot oil soon.
Scott
donk_316
Engine Mechanical Topics
30
02-18-2019 12:19 PM
