Big Bore and SE203, what next?
Thanks Scott, I was re-reading your post and compared the TW37b with the SE203.
Am I reding it right that the two cams are pretty similar?
I looked at Wiseco and it looks like their Kit N. VT2764 (forged 3.875 cr 9.5:1 domed) should be the way to go but I wonder if a hotter cam than the two above wouldn't be in order.
Further thought (I hate it when i open the engine upgrade Pandora box!), I should buy new cylinders shouldn't I?
Thanks Scott, I was re-reading your post and compared the TW37b with the SE203. Am I reding it right that the two cams are pretty similar?
I looked at Wiseco and it looks like their Kit N. VT2764 (forged 3.875 cr 9.5:1 domed) should be the way to go but I wonder if a hotter cam than the two above wouldn't be in order. Further thought (I hate it when i open the engine upgrade Pandora box!), I should buy new cylinders shouldn't I?
No need for new cylinders, use the same OEM pistons your are running or the Wiseco but get .010" OS and hone the OEM cylinders to fit. Sticking with Harley cylinder/pistons is certainly not mandatory but IMHO, a good idea.
Our Stage II heads come off the flow bench hover at 150 cfm @ 10", keying on the low and mid-lift numbers, to start the cylinder fill process asap.
Key, to how we are getting those 98"er/37 cam builds to pop those numbers, at 10.0 cr.
Another interesting, often overlooked cam that will bring it, is an S&S .570, at 10.0 cr.
Jim Kennedy of Paradise Perfomance, Matoon, ILL, recently tuned one our 98" engine combo's to 108/115 thru Rhinehart duals, using that cam.
Scott
Scott
nightrider05
Exhaust System Topics
01-10-2013 09:00 AM
