Screamin Eagle 42mm Carb
12-12-2006, 01:39 AM
What are the factory jet sizes in the Screamin Eagle 42mm carb from Harley? Just curious because I get some decel popping from my pro streets...
12-13-2006, 03:44 AM
RE: Screamin Eagle 42mm Carb
You mean the S/E CV 44 carb? If so than should be a 48/l needle/220. If you have some decel popping, first check for intake/exhast leaks. If not than play with idle a little, up or down. See if that works before rejetting.
12-13-2006, 04:29 PM
25 pilot jet
160 main jet
97 needle
70 accel pump nozzle
12-14-2006, 12:39 AM
thanks murphdog
Classic Beast
EVO
05-01-2021 08:08 PM
tracerprix
05-11-2017 06:07 AM
Bykr53
Exhaust System Topics
01-26-2010 10:31 PM
renotunes
Ironhead
12-29-2007 07:39 PM
01pumpkin
02-26-2006 03:58 PM
42 ,
42mm ,
carb ,
carburetor ,
cv ,
cv44 ,
eagle ,
harley ,
jet ,
mainjet ,
manifold ,
mm ,
pump ,
screamin ,
screaming
