Competition Hillside 98" Build vs. Fuel Moto 98" Build - Dyno Maps Please
I see little merit in the suggestion, although it has so far failed to get a single dyno sheet!
I disagree about different dynos giving different numbers. If each was correctly calibrated and the data extracted done to a uniform standard, such as SAE or DIN, comparisons will be valid. That is the whole purpose of establishing universal standards. It is possible to dyno the same bike in California mid summer and again in Colorado mid winter and get similar figures.
Riddle me this, how can putting a carbonfibre wheel on the back of your motorcycle increase your engines horsepower?
It cant, but a dynojet will tell you that it does.
Just throwing out ideas here. It is entirely possible. I wouldn't discount the idea without further investigation.
I don't own and operate a dyno, but if that is possible it seems either they can be misused, or they are not as well regulated as they should be. Why would a manufacturer make and sell a product like a dyno if they are not uniform and comparable? I expect Harley expends a great deal of effort ensuring each bike is as identical as possible, otherwise they wouldn't comply with EPA.
A dynojet only measures the time it takes to accelerate the drum, a computer then does its black magic and spits out a figure it calls horsepower.
Dynojets are so common that they have become the industry standard and force other types of dyno manufacturers into lying to you by correlating REAL power into dynojet hp, after all, who is going to be happy when the eddy current dyno says you only have 100hp and your buddy with the exact same build gets 130hp on a dynojet.
Wow this idea went all to $hit good to see that at least the 2 shops can be logical. I for one wouldn't mind a thread about just 98 builds, parts & over all where the TQ hits & what riding styles each person built up their motor for, a look at the dyno sheet is only a small part of the build.
Makes sence. I was thinking more on the 300mm having more friction. So coming back to the carbon fiber wheel, I'm thinking it would wind up faster due to it's mass weight or will it only go as fast as the mechanics will let it.
