compression releases
12-28-2011, 12:45 AM
Installing 255 cams in a 08 Roadking with a 96 cid. Are compression releases required with a stage 1? Everything I've read is a 96 stage 1 does not require compression releases but if you upgrade from a 96 to a 103 build they are required because of the increased compression. Lots of conflicting info.
Clay
12-28-2011, 05:34 AM
You'll not need them at 96".
Scott
12-28-2011, 05:40 AM
Got SE 255's on my 96" 09 Ultra Starts Fine Hot or Cold without CR ..
12-28-2011, 12:28 PM
Thanks guys. Just received the same info from Jamie at FM.
jpdeville
Engine Mechanical Topics
08-06-2017 02:45 PM
sanlyn
01-22-2013 02:30 PM
troop
04-28-2010 01:02 AM
nmfxstc
01-26-2008 02:28 PM
cwickgo9
Exhaust System Topics
11-27-2007 06:26 AM
