heads pushing oil into breather
Old 12-22-2011 | 11:57 AM
bigirn's Avatar
bigirn
Default heads pushing oil into breather
happy holiday guys.
i have an 06 street glide 107in. with about 58,000 miles on it. ive been noticeing im pushing a little oil out the heads in to the breather tube. any ideals on the fix. i belive it might be the umbrelas is this correct.
thanks
Old 12-22-2011 | 12:22 PM
bigirn's Avatar
bigirn
i am runing the zippers 54 miliameter throtle body. and it came with a small filter that installs betwen the breather tubes. but the oil would leak on the push rod tubes and cause a mess. so i did away with the filter and ran a hose to the ground like my evo. is this some thing to worry about or just run the thing ?
Old 12-22-2011 | 06:09 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd perform a compression test, then a leakdown test, for starters, as that would determine the condition of the engine.
Scott
Old 12-25-2011 | 10:16 AM
bigirn's Avatar
bigirn
what kind of numbers should i be looking for on the compresion test ?
Old 12-25-2011 | 10:22 AM
Shredding rubber's Avatar
Shredding rubber
Check the oil. If it's above the add mark cold it's too full. I have learned from experience to run it a half quart low
Old 12-25-2011 | 10:33 AM
TUCCI's Avatar
TUCCI
Happy Holidays to you as well!
Old 12-26-2011 | 06:52 AM
Hillsidecycle.com
Sponsor
Yes the peak numbers are important, but much more important are variances between the 2 cylinders, and a leakdown test will pinpoint, intake valve, exhaust valve, or ring seal issues.
Scott
Shem77
EVO
33
04-02-2019 03:29 AM
Greg86hd
EVO
06-17-2018 09:20 PM
hddriver
Engine Mechanical Topics
28
10-16-2015 08:24 PM
Sledge
07-24-2012 09:54 AM
tgarrett1
Oil Archive (no new posts)
11-20-2006 11:32 AM
Quick Reply: heads pushing oil into breather
