Sponsored by: Jekill and Hyde
CV carb ...HELP!
Old 12-22-2011, 07:42 PM
jsbridgew's Avatar
jsbridgew
jsbridgew is offline
Originally Posted by Hillsidecycle.com
Even off, it should'nt pi$$ out of the overflow.
Scott
...where's it going to go if it can't vent properly and it's under pressure?
Old 12-28-2011, 12:19 AM
JB's Avatar
JB
JB is offline
The tank should be vented through the cap or caps, the petcock has nothing to do with venting the tank. If the tank were pressurizing and pushing fuel past the needle and seat that would mean the tank was sealed and that during the time when the motor was running it would also start to draw a vacuum in the tank as fuel was removed and would soon starve the engine to the point that it would no longer run. It still looks like its falling back to the needle and seat or like was said above the tanks are not venting between the two.
Old 12-28-2011, 02:14 PM
CafeSportyTC's Avatar
CafeSportyTC
CafeSportyTC is offline
what rebuild kit did you use to seal the sucker back up? it may be a bad needle valve all together.. let me know on brand i may be able to help you!
Old 12-28-2011, 08:38 PM
Crazy Canuck's Avatar
Crazy Canuck
Crazy Canuck is offline
Do you have the stock petcock or an aftermarket one like Pingel? If aftermarket, make sure you plug the little tube on the top back of the carb. Not sure if it has anything to do with your problem but just incase.
Old 12-29-2011, 12:24 PM
str8jacket's Avatar
str8jacket
str8jacket is offline
Originally Posted by jsbridgew
-replaced float needle
Did you replace the seat too, or just the needle? They should be replaced as a set. If you replaced the seat, maybe it's not tightened all the way and leaking past the threads?
It almost has to be either the float level or or leaking needle valve. It would take a lot of pressure to force fuel past a properly seated needle valve.
kansasroadking
01-20-2024 09:42 PM
89FLHTC
Carburetor Related
05-06-2016 11:40 AM
Stan in Birmingham ala
Carburetor Related
08-28-2013 04:16 PM
jtmurph00
05-13-2010 11:14 AM
stone_rider420
04-14-2007 11:03 AM
Quick Reply: CV carb ...HELP!
